“603 decline” with disabled voicemail + call waiting
VitalPBX Community Support Reporting an Issue “603 decline” with disabled voicemail + call waiting
  • Post
    Sstep
    Participant
    Up
    0
    Down
    Hello. We do not use voicemail and call waiting, these options are disabled for extensions. If the subscriber calls the second person who is talking, we get “603 decline” instead of “486 Busy”.
    I tried to reproduce the same on Freepbx and got a normal “486 Busy”
    Distro CentOS Linux release 7.8.2003 (Core)
    Kernel 3.10.0-1127.19.1.el7.x86_64
    Asterisk 17.7.0
    VitalPBX 3.0.3-4
    I’m new to asterisk, but if you tell me what logs are needed, I’m ready to provide
    0
Viewing 1 replies (of 1 total)
  • Replies
    Sstep
    Participant
    Up
    0
    Down
    up? is this normal behavior?
    Log:
    [2020-11-22 16:01:05] VERBOSE[30198] pbx_variables.c: Setting global variable 'SIPDOMAIN' to '192.168.0.157'
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [89250363499@cos-all:1] NoOp("PJSIP/199-00000038", "More than on digit pattern") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [89250363499@cos-all:2] Gosub("PJSIP/199-00000038", "s,1(89250363499)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:1] Set("PJSIP/199-00000038", "EXTENSION=89250363499") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:2] NoOp("PJSIP/199-00000038", "Dialing 89250363499 from 199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:3] Gosub("PJSIP/199-00000038", "sub-set-global-vars,s,1(2d97ae06e1471d24,89250363499,parking-1)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-global-vars:1] NoOp("PJSIP/199-00000038", "Setting Global Vars") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-global-vars:2] Set("PJSIP/199-00000038", "TENANT_PATH=2d97ae06e1471d24") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-global-vars:3] Set("PJSIP/199-00000038", "PREFIX=") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-global-vars:4] Set("PJSIP/199-00000038", "__PICKUPMARK=89250363499") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-global-vars:5] Set("PJSIP/199-00000038", "__PARKINGLOT=parking-1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-global-vars:6] Set("PJSIP/199-00000038", "__DYNAMIC_FEATURES=custom-features") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-global-vars:7] Set("PJSIP/199-00000038", "ICALL=no") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-global-vars:8] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:4] Gosub("PJSIP/199-00000038", "sub-set-call-vars,s,1(2d97ae06e1471d24,89250363499,1,cos-all,ARS-all)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:1] NoOp("PJSIP/199-00000038", "Setting Call Vars") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:2] Set("PJSIP/199-00000038", "_TENANT=2d97ae06e1471d24") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:3] Set("PJSIP/199-00000038", "_CALL_DESTINATION=89250363499") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:4] Set("PJSIP/199-00000038", "_COS_ID=1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:5] Set("PJSIP/199-00000038", "_COS_NAME=cos-all") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:6] Set("PJSIP/199-00000038", "__TRANSFER_CONTEXT=cos-all") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:7] Set("PJSIP/199-00000038", "_ARS=ARS-all") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:8] Set("PJSIP/199-00000038", "CDR(tenant)=vitalpbx") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:9] Set("PJSIP/199-00000038", "CDR(destination)=89250363499") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:10] Set("PJSIP/199-00000038", "CDR(trunk)=") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:11] Set("PJSIP/199-00000038", "CDR(did)=") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:12] Set("PJSIP/199-00000038", "__CALLID=1606050065.108") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:13] ExecIf("PJSIP/199-00000038", "0?Set(CHANNEL(language)=)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-set-call-vars:14] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:5] Gosub("PJSIP/199-00000038", "sub-construct-cid,s,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:1] NoOp("PJSIP/199-00000038", "Building CID") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:2] Set("PJSIP/199-00000038", "_CALL_SOURCE=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:3] Set("PJSIP/199-00000038", "_CS=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:4] GotoIf("PJSIP/199-00000038", "0?return") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:5] Gosub("PJSIP/199-00000038", "sub-get-device-tree,s,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:1] NoOp("PJSIP/199-00000038", "Configuring Device Tree") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:2] Set("PJSIP/199-00000038", "DEV_TECHNOLOGY=PJSIP") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:3] GosubIf("PJSIP/199-00000038", "0?s-local,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:4] GotoIf("PJSIP/199-00000038", "0?return") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:5] GotoIf("PJSIP/199-00000038", "1?pjsip") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (sub-get-device-tree,s,9)
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:9] NoOp("PJSIP/199-00000038", "A PJSIP") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:10] Set("PJSIP/199-00000038", "DEV_USER=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:11] Goto("PJSIP/199-00000038", "build_interface") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (sub-get-device-tree,s,13)
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:13] Set("PJSIP/199-00000038", "INTERFACE=PJSIP/199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:14] Set("PJSIP/199-00000038", "DEV_TREE=devices/PJSIP/199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-get-device-tree:15] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:6] GotoIf("PJSIP/199-00000038", "0?return") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:7] Set("PJSIP/199-00000038", "_CALL_SOURCE=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:8] Set("PJSIP/199-00000038", "_CS=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:9] ExecIf("PJSIP/199-00000038", "1?Set(CALLERID(all)="199" <199>)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:10] Set("PJSIP/199-00000038", "_CID_CONSTRUCTED=yes") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:11] NoOp("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:12] Set("PJSIP/199-00000038", "CDR(source)=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-construct-cid:13] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:6] Gosub("PJSIP/199-00000038", "set-global-tenant-vars,s,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@set-global-tenant-vars:1] NoOp("PJSIP/199-00000038", "Setting Global Vars for vitalpbx Tenant") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@set-global-tenant-vars:2] Set("PJSIP/199-00000038", "__TENANT_PATH=2d97ae06e1471d24") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@set-global-tenant-vars:3] Set("PJSIP/199-00000038", "__TENANT_PREFIX=") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@set-global-tenant-vars:4] Set("PJSIP/199-00000038", "__QUEUE_AGENTS_CONTEXT=queue-call-to-agents") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@set-global-tenant-vars:5] Set("PJSIP/199-00000038", "__FOLLOWME_CONTEXT=ext-followme") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@set-global-tenant-vars:6] Set("PJSIP/199-00000038", "__HINTS_CONTEXT=extension-hints") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@set-global-tenant-vars:7] Set("PJSIP/199-00000038", "__DEFAULT_COS=cos-all") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@set-global-tenant-vars:8] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:7] GotoIf("PJSIP/199-00000038", "0?local-dialing") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:8] NoOp("PJSIP/199-00000038", "Check if is an Emergency Call") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:9] GotoIf("PJSIP/199-00000038", "0?emergency-calls,89250363499,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:10] Gosub("PJSIP/199-00000038", "sub-lockphone-check,s,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-lockphone-check:1] NoOp("PJSIP/199-00000038", "SUB: LOCK PHONE CHECK") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-lockphone-check:2] GotoIf("PJSIP/199-00000038", "0?unlock") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-lockphone-check:3] GotoIf("PJSIP/199-00000038", "0?unlock") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-lockphone-check:4] GotoIf("PJSIP/199-00000038", "0?unlock") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-lockphone-check:5] GotoIf("PJSIP/199-00000038", "0?unlock") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-lockphone-check:6] GotoIf("PJSIP/199-00000038", "0?:unlock") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (sub-lockphone-check,s,12)
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-lockphone-check:12] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:11] Gosub("PJSIP/199-00000038", "sub-local-dialing,s,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-local-dialing:1] NoOp("PJSIP/199-00000038", "Trying to determine if is a local extension") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-local-dialing:2] GotoIf("PJSIP/199-00000038", "0?:return") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (sub-local-dialing,s,5)
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-local-dialing:5] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:12] GotoIf("PJSIP/199-00000038", "0?end-call") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@cos-all:13] Goto("PJSIP/199-00000038", "cos-all-post,89250363499,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (cos-all-post,89250363499,1)
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [89250363499@cos-all-post:1] NoOp("PJSIP/199-00000038", "Outbound Route: Default") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [89250363499@cos-all-post:2] Gosub("PJSIP/199-00000038", "sub-setup-call-type,s,1(outgoing)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-setup-call-type:1] NoOp("PJSIP/199-00000038", "Determinating Call Type") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-setup-call-type:2] GotoIf("PJSIP/199-00000038", "0?return") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-setup-call-type:3] Gosub("PJSIP/199-00000038", "s-outgoing,1()") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-outgoing@sub-setup-call-type:1] NoOp("PJSIP/199-00000038", "Outgoing Call") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-outgoing@sub-setup-call-type:2] Set("PJSIP/199-00000038", "__CALL_TYPE=3") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-outgoing@sub-setup-call-type:3] Set("PJSIP/199-00000038", "__CALL_TYPE_LABEL=OUT") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-outgoing@sub-setup-call-type:4] GosubIf("PJSIP/199-00000038", "0?s-transit,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-outgoing@sub-setup-call-type:5] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-setup-call-type:4] Set("PJSIP/199-00000038", "__CALL_TYPE_CONFIGURED=yes") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-setup-call-type:5] Set("PJSIP/199-00000038", "CDR(calltype)=3") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-setup-call-type:6] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [89250363499@cos-all-post:3] NoOp("PJSIP/199-00000038", "Start to Dial Trunks") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [89250363499@cos-all-post:4] Set("PJSIP/199-00000038", "DNID=79250363499") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [89250363499@cos-all-post:5] Goto("PJSIP/199-00000038", "s-1,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (cos-all-post,s-1,1)
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-1@cos-all-post:1] Set("PJSIP/199-00000038", "__CONFIGURED_BY_TENANT=yes") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-1@cos-all-post:2] Gosub("PJSIP/199-00000038", "sub-construct-cid,s-external,1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:1] NoOp("PJSIP/199-00000038", "Setting External CID") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:2] Set("PJSIP/199-00000038", "EXTENSION_NUMBER=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:3] GotoIf("PJSIP/199-00000038", "0?return") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:4] GotoIf("PJSIP/199-00000038", "0?return") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:5] Set("PJSIP/199-00000038", "EMERGENCY_CALL=no") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:6] Set("PJSIP/199-00000038", "EXTENSION_EMERGENCY_CID=") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:7] Set("PJSIP/199-00000038", "DYNAMIC_EXTERNAL_CID=no") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:8] ExecIf("PJSIP/199-00000038", "1?Set(EXTENSION_EMERGENCY_CID=)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:9] ExecIf("PJSIP/199-00000038", "1?Set(DYNAMIC_EXTERNAL_CID=yes)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:10] GotoIf("PJSIP/199-00000038", "1?check-emergency") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (sub-construct-cid,s-external,12)
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:12] GotoIf("PJSIP/199-00000038", "0?:info") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (sub-construct-cid,s-external,20)
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:20] NoOp("PJSIP/199-00000038", "CID Name: 199, CID Number: 199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:21] Set("PJSIP/199-00000038", "SEND_CID=yes") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:22] ExecIf("PJSIP/199-00000038", "0?Set(CALLERID(name-pres)=prohib_passed_screen)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:23] ExecIf("PJSIP/199-00000038", "0?Set(CALLERID(num-pres)=prohib_passed_screen)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:24] Set("PJSIP/199-00000038", "__EXT_CID_CONSTRUCTED=yes") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:25] Set("PJSIP/199-00000038", "CDR(source)=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-external@sub-construct-cid:26] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s-1@cos-all-post:3] Gosub("PJSIP/199-00000038", "trk-1,79250363499,1(from-trk-grp)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1:1] Set("PJSIP/199-00000038", "_NTD=79250363499") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1:2] Gosub("PJSIP/199-00000038", "trk-1-dial,79250363499,1(from-trk-grp)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:1] NoOp("PJSIP/199-00000038", "Trunk: Zadarma_PJSIP") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:2] NoOp("PJSIP/199-00000038", "Dialing: 79250363499") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:3] Set("PJSIP/199-00000038", "CDR(trunk)=1") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:4] Gosub("PJSIP/199-00000038", "sub-setup-call-type,s,1(outgoing,no)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-setup-call-type:3] Gosub("PJSIP/199-00000038", "s-outgoing,1(no)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:5] NoOp("PJSIP/199-00000038", "Configuring Trunk Parameters") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:6] ExecIf("PJSIP/199-00000038", "1?Set(CHANNEL(musicclass)=default):") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:7] Set("PJSIP/199-00000038", "__TRUNK_MOH_SET=yes") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:8] Set("PJSIP/199-00000038", "__TRKDIALOPTIONS=kKt") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:9] Set("PJSIP/199-00000038", "ORIGINATOR=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:10] Set("PJSIP/199-00000038", "RING_TIME=90") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:11] Set("PJSIP/199-00000038", "CALLED=79250363499") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:12] Set("PJSIP/199-00000038", "__CIDNUM=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:13] Set("PJSIP/199-00000038", "__CIDNAME=199") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:14] Set("PJSIP/199-00000038", "FORCE_RECORDING=no") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:15] Set("PJSIP/199-00000038", "FILTERED_NUMBER=79250363499") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] pbx.c: Executing [79250363499@trk-1-dial:16] Dial("PJSIP/199-00000038", "PJSIP/79250363499@956740,90,kKtU(sub-call-recording^2d97ae06e1471d24^199^79250363499^no)") in new stack
    [2020-11-22 16:01:05] VERBOSE[7116][C-00000030] app_dial.c: Called PJSIP/79250363499@956740
    [2020-11-22 16:01:07] VERBOSE[7116][C-00000030] app_dial.c: PJSIP/956740-00000039 is making progress passing it to PJSIP/199-00000038
    [2020-11-22 16:01:07] VERBOSE[1322] chan_sip.c: Extension Changed 199[extension-hints] new state InUse for Notify User 200
    [2020-11-22 16:01:11] VERBOSE[7116][C-00000030] app_dial.c: PJSIP/956740-00000039 is ringing
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] app_dial.c: PJSIP/956740-00000039 answered PJSIP/199-00000038
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] app_stack.c: PJSIP/956740-00000039 Internal Gosub(sub-call-recording,s,1(2d97ae06e1471d24,199,79250363499,no)) start
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:1] NoOp("PJSIP/956740-00000039", "Check if call will be recorded on tenant 2d97ae06e1471d24") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:2] NoOp("PJSIP/956740-00000039", "Call Type: 3 ") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:3] Set("PJSIP/956740-00000039", "TENANT=2d97ae06e1471d24") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:4] Set("PJSIP/956740-00000039", "CALLER=199") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:5] Set("PJSIP/956740-00000039", "CALLEE=79250363499") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:6] Set("PJSIP/956740-00000039", "APP_FORCE=no") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:7] GotoIf("PJSIP/956740-00000039", "1?:rec_no_available") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:8] GotoIf("PJSIP/956740-00000039", "0?perform-recording") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:9] GotoIf("PJSIP/956740-00000039", "0?perform-recording") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:10] GotoIf("PJSIP/956740-00000039", "0?perform-recording") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:11] GotoIf("PJSIP/956740-00000039", "0?perform-recording") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:12] GotoIf("PJSIP/956740-00000039", "1?perform-recording") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (sub-call-recording,s,14)
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:14] Gosub("PJSIP/956740-00000039", "sub-perform-recording,s,1") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-perform-recording:1] NoOp("PJSIP/956740-00000039", "Perform Call Recording") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-perform-recording:2] Set("PJSIP/956740-00000039", "RECORDING_ID=1606050065.109") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-perform-recording:3] Set("PJSIP/956740-00000039", "APP_TYPE=NONE") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-perform-recording:4] Set("PJSIP/956740-00000039", "AUDIO_FILE=160116-OUT-NONE-199-89250363499-1606050065.109") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-perform-recording:5] Set("PJSIP/956740-00000039", "RECORDING_FORMAT=wav") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-perform-recording:6] Set("PJSIP/956740-00000039", "__REC_FILENAME=/var/spool/asterisk/monitor/2020/11/22/160116-OUT-NONE-199-89250363499-1606050065.109.wav") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-perform-recording:7] GotoIf("PJSIP/956740-00000039", "0?:set_rec_file") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (sub-perform-recording,s,10)
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-perform-recording:10] Set("PJSIP/956740-00000039", "CDR(recfile)=/var/spool/asterisk/monitor/2020/11/22/160116-OUT-NONE-199-89250363499-1606050065.109.wav") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-perform-recording:11] MixMonitor("PJSIP/956740-00000039", "/var/spool/asterisk/monitor/2020/11/22/160116-OUT-NONE-199-89250363499-1606050065.109.wav,b,") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-perform-recording:12] Return("PJSIP/956740-00000039", "") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:15] Goto("PJSIP/956740-00000039", "return") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx_builtins.c: Goto (sub-call-recording,s,17)
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] pbx.c: Executing [s@sub-call-recording:17] Return("PJSIP/956740-00000039", "") in new stack
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] app_stack.c: Spawn extension (trk-1-in, , 1) exited non-zero on 'PJSIP/956740-00000039'
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] app_stack.c: PJSIP/956740-00000039 Internal Gosub(sub-call-recording,s,1(2d97ae06e1471d24,199,79250363499,no)) complete GOSUB_RETVAL=
    [2020-11-22 16:01:16] VERBOSE[7135][C-00000030] app_mixmonitor.c: Begin MixMonitor Recording PJSIP/956740-00000039
    [2020-11-22 16:01:16] VERBOSE[7136][C-00000030] bridge_channel.c: Channel PJSIP/956740-00000039 joined 'simple_bridge' basic-bridge <df684ed0-db0a-4dc3-8921-7205e21fd4d3>
    [2020-11-22 16:01:16] VERBOSE[7116][C-00000030] bridge_channel.c: Channel PJSIP/199-00000038 joined 'simple_bridge' basic-bridge <df684ed0-db0a-4dc3-8921-7205e21fd4d3>
    [2020-11-22 16:01:23] VERBOSE[30198] pbx_variables.c: Setting global variable 'SIPDOMAIN' to '192.168.0.157'
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@cos-all:1] NoOp("PJSIP/186-0000003a", "More than on digit pattern") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@cos-all:2] Gosub("PJSIP/186-0000003a", "s,1(199)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:1] Set("PJSIP/186-0000003a", "EXTENSION=199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:2] NoOp("PJSIP/186-0000003a", "Dialing 199 from 186") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:3] Gosub("PJSIP/186-0000003a", "sub-set-global-vars,s,1(2d97ae06e1471d24,199,parking-1)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-global-vars:1] NoOp("PJSIP/186-0000003a", "Setting Global Vars") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-global-vars:2] Set("PJSIP/186-0000003a", "TENANT_PATH=2d97ae06e1471d24") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-global-vars:3] Set("PJSIP/186-0000003a", "PREFIX=") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-global-vars:4] Set("PJSIP/186-0000003a", "__PICKUPMARK=199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-global-vars:5] Set("PJSIP/186-0000003a", "__PARKINGLOT=parking-1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-global-vars:6] Set("PJSIP/186-0000003a", "__DYNAMIC_FEATURES=custom-features") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-global-vars:7] Set("PJSIP/186-0000003a", "ICALL=no") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-global-vars:8] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:4] Gosub("PJSIP/186-0000003a", "sub-set-call-vars,s,1(2d97ae06e1471d24,199,1,cos-all,ARS-all)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:1] NoOp("PJSIP/186-0000003a", "Setting Call Vars") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:2] Set("PJSIP/186-0000003a", "_TENANT=2d97ae06e1471d24") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:3] Set("PJSIP/186-0000003a", "_CALL_DESTINATION=199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:4] Set("PJSIP/186-0000003a", "_COS_ID=1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:5] Set("PJSIP/186-0000003a", "_COS_NAME=cos-all") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:6] Set("PJSIP/186-0000003a", "__TRANSFER_CONTEXT=cos-all") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:7] Set("PJSIP/186-0000003a", "_ARS=ARS-all") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:8] Set("PJSIP/186-0000003a", "CDR(tenant)=vitalpbx") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:9] Set("PJSIP/186-0000003a", "CDR(destination)=199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:10] Set("PJSIP/186-0000003a", "CDR(trunk)=") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:11] Set("PJSIP/186-0000003a", "CDR(did)=") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:12] Set("PJSIP/186-0000003a", "__CALLID=1606050083.110") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:13] ExecIf("PJSIP/186-0000003a", "0?Set(CHANNEL(language)=)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-set-call-vars:14] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:5] Gosub("PJSIP/186-0000003a", "sub-construct-cid,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:1] NoOp("PJSIP/186-0000003a", "Building CID") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:2] Set("PJSIP/186-0000003a", "_CALL_SOURCE=186") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:3] Set("PJSIP/186-0000003a", "_CS=186") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:4] GotoIf("PJSIP/186-0000003a", "0?return") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:5] Gosub("PJSIP/186-0000003a", "sub-get-device-tree,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:1] NoOp("PJSIP/186-0000003a", "Configuring Device Tree") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:2] Set("PJSIP/186-0000003a", "DEV_TECHNOLOGY=PJSIP") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:3] GosubIf("PJSIP/186-0000003a", "0?s-local,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:4] GotoIf("PJSIP/186-0000003a", "0?return") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:5] GotoIf("PJSIP/186-0000003a", "1?pjsip") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-get-device-tree,s,9)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:9] NoOp("PJSIP/186-0000003a", "A PJSIP") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:10] Set("PJSIP/186-0000003a", "DEV_USER=186") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:11] Goto("PJSIP/186-0000003a", "build_interface") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-get-device-tree,s,13)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:13] Set("PJSIP/186-0000003a", "INTERFACE=PJSIP/186") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:14] Set("PJSIP/186-0000003a", "DEV_TREE=devices/PJSIP/186") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-get-device-tree:15] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:6] GotoIf("PJSIP/186-0000003a", "0?return") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:7] Set("PJSIP/186-0000003a", "_CALL_SOURCE=186") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:8] Set("PJSIP/186-0000003a", "_CS=186") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:9] ExecIf("PJSIP/186-0000003a", "1?Set(CALLERID(all)="Сергей Степанкин" <186>)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:10] Set("PJSIP/186-0000003a", "_CID_CONSTRUCTED=yes") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:11] NoOp("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:12] Set("PJSIP/186-0000003a", "CDR(source)=186") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-construct-cid:13] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:6] Gosub("PJSIP/186-0000003a", "set-global-tenant-vars,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@set-global-tenant-vars:1] NoOp("PJSIP/186-0000003a", "Setting Global Vars for vitalpbx Tenant") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@set-global-tenant-vars:2] Set("PJSIP/186-0000003a", "__TENANT_PATH=2d97ae06e1471d24") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@set-global-tenant-vars:3] Set("PJSIP/186-0000003a", "__TENANT_PREFIX=") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@set-global-tenant-vars:4] Set("PJSIP/186-0000003a", "__QUEUE_AGENTS_CONTEXT=queue-call-to-agents") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@set-global-tenant-vars:5] Set("PJSIP/186-0000003a", "__FOLLOWME_CONTEXT=ext-followme") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@set-global-tenant-vars:6] Set("PJSIP/186-0000003a", "__HINTS_CONTEXT=extension-hints") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@set-global-tenant-vars:7] Set("PJSIP/186-0000003a", "__DEFAULT_COS=cos-all") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@set-global-tenant-vars:8] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:7] GotoIf("PJSIP/186-0000003a", "0?local-dialing") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:8] NoOp("PJSIP/186-0000003a", "Check if is an Emergency Call") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:9] GotoIf("PJSIP/186-0000003a", "0?emergency-calls,199,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:10] Gosub("PJSIP/186-0000003a", "sub-lockphone-check,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-lockphone-check:1] NoOp("PJSIP/186-0000003a", "SUB: LOCK PHONE CHECK") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-lockphone-check:2] GotoIf("PJSIP/186-0000003a", "0?unlock") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-lockphone-check:3] GotoIf("PJSIP/186-0000003a", "0?unlock") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-lockphone-check:4] GotoIf("PJSIP/186-0000003a", "0?unlock") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-lockphone-check:5] GotoIf("PJSIP/186-0000003a", "0?unlock") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-lockphone-check:6] GotoIf("PJSIP/186-0000003a", "0?:unlock") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-lockphone-check,s,12)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-lockphone-check:12] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@cos-all:11] Gosub("PJSIP/186-0000003a", "sub-local-dialing,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-local-dialing:1] NoOp("PJSIP/186-0000003a", "Trying to determine if is a local extension") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-local-dialing:2] GotoIf("PJSIP/186-0000003a", "1?:return") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-local-dialing:3] Set("PJSIP/186-0000003a", "EXTENSION_TO_DIAL=199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-local-dialing:4] Goto("PJSIP/186-0000003a", "199,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-local-dialing,199,1)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:1] NoOp("PJSIP/186-0000003a", "Dialing Local Extension") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:2] Gosub("PJSIP/186-0000003a", "sub-setup-call-type,s,1(internal)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-setup-call-type:1] NoOp("PJSIP/186-0000003a", "Determinating Call Type") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-setup-call-type:2] GotoIf("PJSIP/186-0000003a", "0?return") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-setup-call-type:3] Gosub("PJSIP/186-0000003a", "s-internal,1()") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-internal@sub-setup-call-type:1] NoOp("PJSIP/186-0000003a", "Internal Call") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-internal@sub-setup-call-type:2] Set("PJSIP/186-0000003a", "__CALL_TYPE=1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-internal@sub-setup-call-type:3] Set("PJSIP/186-0000003a", "__CALL_TYPE_LABEL=LOCAL") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-internal@sub-setup-call-type:4] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-setup-call-type:4] Set("PJSIP/186-0000003a", "__CALL_TYPE_CONFIGURED=yes") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-setup-call-type:5] Set("PJSIP/186-0000003a", "CDR(calltype)=1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-setup-call-type:6] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:3] Set("PJSIP/186-0000003a", "_DESTINATION_STATE=INUSE") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:4] Set("PJSIP/186-0000003a", "_DESTINATION_NUMBER=199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:5] Set("PJSIP/186-0000003a", "_DESTINATION_COS_NAME=cos-all") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:6] Gosub("PJSIP/186-0000003a", "sub-check-cos-privacy,s,1(cos-all,1,cos-all)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-cos-privacy:1] NoOp("PJSIP/186-0000003a", "Checking Privacy of CoS: cos-all") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-cos-privacy:2] GotoIf("PJSIP/186-0000003a", "1?:no_local") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-cos-privacy:3] Set("PJSIP/186-0000003a", "CALLER_COS_ID=1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-cos-privacy:4] Set("PJSIP/186-0000003a", "CALLER_COS_NAME=cos-all") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-cos-privacy:5] Set("PJSIP/186-0000003a", "CALLED_COS_ID=1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-cos-privacy:6] GotoIf("PJSIP/186-0000003a", "1?same_cos") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-check-cos-privacy,s,17)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-cos-privacy:17] NoOp("PJSIP/186-0000003a", "The caller CoS and Callee CoS are the same") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-cos-privacy:18] Goto("PJSIP/186-0000003a", "return") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-check-cos-privacy,s,22)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-cos-privacy:22] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:7] Set("PJSIP/186-0000003a", "DIAL_STRING=PJSIP/199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:8] Set("PJSIP/186-0000003a", "DB(2d97ae06e1471d24/LASTCALLER/199)=186") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:9] Set("PJSIP/186-0000003a", "IGNORE_DIVERSIONS=") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:10] Set("PJSIP/186-0000003a", "QUEUE_CALL=") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:11] GosubIf("PJSIP/186-0000003a", "0?sub-queue-members,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:12] GosubIf("PJSIP/186-0000003a", "0?:sub-check-diversions,s,1(predialing)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-diversions:1] NoOp("PJSIP/186-0000003a", "Checking diversions for extension 199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-diversions:2] Set("PJSIP/186-0000003a", "OLD_CALLER_ID="Сергей Степанкин" <186>") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-diversions:3] GosubIf("PJSIP/186-0000003a", "0?:return") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-diversions:9] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-diversions:4] ExecIf("PJSIP/186-0000003a", "0?Set(CALLERID(all)="199" <199>)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-diversions:5] Set("PJSIP/186-0000003a", "__CALL_ORIGIN=diversions") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-diversions:6] Set("PJSIP/186-0000003a", "__DIVERSION_ORIGIN=199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-diversions:7] Gosub("PJSIP/186-0000003a", "s-predialing,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-predialing@sub-check-diversions:1] NoOp("PJSIP/186-0000003a", "Diversions on pre-dialing") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-predialing@sub-check-diversions:2] GosubIf("PJSIP/186-0000003a", "0?:diversion-testing,1(Do not Disturb,DND,,,dnd)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [diversion-testing@sub-check-diversions:1] NoOp("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [diversion-testing@sub-check-diversions:2] GotoIf("PJSIP/186-0000003a", "0?:next-diversion") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-check-diversions,diversion-testing,32)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [diversion-testing@sub-check-diversions:32] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-predialing@sub-check-diversions:3] Gosub("PJSIP/186-0000003a", "diversion-testing,1(Call Forward Immeditely,CFI,,,toggle_cfi)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-predialing@sub-check-diversions:4] GosubIf("PJSIP/186-0000003a", "0?:diversion-testing,1(Boss Secretray,BOSS,,,boss_secretary)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-predialing@sub-check-diversions:5] GosubIf("PJSIP/186-0000003a", "0?:diversion-testing,1(Personal Assistant,PEA,sub-personal-assistant,s,1)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-predialing@sub-check-diversions:6] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-diversions:8] Set("PJSIP/186-0000003a", "CALLERID(all)="Сергей Степанкин" <186>") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:13] GotoIf("PJSIP/186-0000003a", "0?post-dial") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:14] Gosub("PJSIP/186-0000003a", "parse-dial-string,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:1] NoOp("PJSIP/186-0000003a", "Parsing dial string: PJSIP/199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:2] Set("PJSIP/186-0000003a", "NEW_DIAL_STRING=") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:3] Set("PJSIP/186-0000003a", "COUNTER=1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:4] Set("PJSIP/186-0000003a", "CURRENT_DEVICE=PJSIP/199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:5] While("PJSIP/186-0000003a", "1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:6] GosubIf("PJSIP/186-0000003a", "0?send-push,s,1(PJSIP/199)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:7] Set("PJSIP/186-0000003a", "TECHNOLOGY=PJSIP") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:8] Set("PJSIP/186-0000003a", "USER=199") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:9] GotoIf("PJSIP/186-0000003a", "1?:regular") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:10] Set("PJSIP/186-0000003a", "PARSED_DEV=PJSIP/199/sip:199@192.168.7.172:5060") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:11] ExecIf("PJSIP/186-0000003a", "0?Set(PARSED_DEV=PJSIP/199)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:12] Goto("PJSIP/186-0000003a", "append") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (parse-dial-string,s,14)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:14] GotoIf("PJSIP/186-0000003a", "1?:concatenate") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:15] Set("PJSIP/186-0000003a", "NEW_DIAL_STRING=PJSIP/199/sip:199@192.168.7.172:5060") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:16] Goto("PJSIP/186-0000003a", "next") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (parse-dial-string,s,19)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:19] Set("PJSIP/186-0000003a", "COUNTER=2") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:20] Set("PJSIP/186-0000003a", "CURRENT_DEVICE=") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:21] EndWhile("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:5] While("PJSIP/186-0000003a", "0") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:22] NoOp("PJSIP/186-0000003a", "New dialstring: PJSIP/199/sip:199@192.168.7.172:5060") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:23] Set("PJSIP/186-0000003a", "DIAL_STRING=PJSIP/199/sip:199@192.168.7.172:5060") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@parse-dial-string:24] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:15] NoOp("PJSIP/186-0000003a", "Configuring Dial Settings") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:16] Set("PJSIP/186-0000003a", "RING_TIME=60") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:17] Set("PJSIP/186-0000003a", "RING_TIME=60") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:18] Set("PJSIP/186-0000003a", "RING_TIME=60") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:19] Set("PJSIP/186-0000003a", "DIAL_OPTIONS=kKt") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:20] Set("PJSIP/186-0000003a", "DIAL_OPTIONS=kKt") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:21] GotoIf("PJSIP/186-0000003a", "0?:answermode") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-local-dialing,199,25)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:25] Set("PJSIP/186-0000003a", "ANSWER_MODE=disable") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:26] Set("PJSIP/186-0000003a", "ANSWER_MODE=disable") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:27] ExecIf("PJSIP/186-0000003a", "0?Set(DIAL_OPTIONS=kKtb(sub-auto-answer^s^1))") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:28] Set("PJSIP/186-0000003a", "IS_HOT_DESK=no") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:29] Set("PJSIP/186-0000003a", "MOH_CLASS=default") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:30] GosubIf("PJSIP/186-0000003a", "0?sub-set-moh,s,1(default)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:31] GotoIf("PJSIP/186-0000003a", "1?busy-here") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-local-dialing,199,48)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:48] Set("PJSIP/186-0000003a", "_CALL_STATUS=BUSY") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:49] GosubIf("PJSIP/186-0000003a", "0?:sub-check-diversions,s,1(postdialing)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-check-diversions:7] Gosub("PJSIP/186-0000003a", "s-postdialing,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-postdialing@sub-check-diversions:1] NoOp("PJSIP/186-0000003a", "Diversions on post-dialing") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-postdialing@sub-check-diversions:2] Gosub("PJSIP/186-0000003a", "diversion-testing,1(Follow Me,FWM,ext-followme,FW199,follow_me)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-postdialing@sub-check-diversions:3] GosubIf("PJSIP/186-0000003a", "0?call-forward,1(CFU,toggle_cfu)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-postdialing@sub-check-diversions:4] GosubIf("PJSIP/186-0000003a", "0?call-forward,1(CFU,toggle_cfu)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-postdialing@sub-check-diversions:5] GosubIf("PJSIP/186-0000003a", "1?call-forward,1(CFB,toggle_cfb)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [call-forward@sub-check-diversions:1] NoOp("PJSIP/186-0000003a", "CALL FOWARDING") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [call-forward@sub-check-diversions:2] GotoIf("PJSIP/186-0000003a", "0?:return") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-check-diversions,call-forward,10)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [call-forward@sub-check-diversions:10] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-postdialing@sub-check-diversions:6] GosubIf("PJSIP/186-0000003a", "0?call-forward,1(CFN,toggle_cfn)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s-postdialing@sub-check-diversions:7] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:50] GotoIf("PJSIP/186-0000003a", "0?end_call") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:51] GotoIf("PJSIP/186-0000003a", "0?end_call") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:52] Gosub("PJSIP/186-0000003a", "sub-leave-vm,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-leave-vm:1] NoOp("PJSIP/186-0000003a", "Leave Voicemail") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-leave-vm:2] Set("PJSIP/186-0000003a", "VM_OPTIONS=b") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-leave-vm:3] Set("PJSIP/186-0000003a", "VM_OPTIONS=bs") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-leave-vm:4] GotoIf("PJSIP/186-0000003a", "0?:vm_disabled") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-leave-vm,s,8)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-leave-vm:8] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:53] GosubIf("PJSIP/186-0000003a", "1?sub-request-cc,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-request-cc:1] NoOp("PJSIP/186-0000003a", "Trying to request call completion") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-request-cc:2] GotoIf("PJSIP/186-0000003a", "1?:return") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-request-cc:3] GotoIf("PJSIP/186-0000003a", "0?:return") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-request-cc,s,11)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-request-cc:11] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [199@sub-local-dialing:54] Hangup("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Spawn extension (sub-local-dialing, 199, 54) exited non-zero on 'PJSIP/186-0000003a'
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [h@sub-local-dialing:1] NoOp("PJSIP/186-0000003a", "Finishing the call") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [h@sub-local-dialing:2] GosubIf("PJSIP/186-0000003a", "0?dynamic-routing-connected,s,1(,186)") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [h@sub-local-dialing:3] GotoIf("PJSIP/186-0000003a", "0?call_ended") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [h@sub-local-dialing:4] GosubIf("PJSIP/186-0000003a", "0?wake-up-no-answered,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [h@sub-local-dialing:5] Gosub("PJSIP/186-0000003a", "sub-call-completion-check,s,1") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-call-completion-check:1] NoOp("PJSIP/186-0000003a", "FEATURE: CALL COMPLETION CHECK") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-call-completion-check:2] Set("PJSIP/186-0000003a", "CC_MODE=none") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-call-completion-check:3] Set("PJSIP/186-0000003a", "CC_MODE=none") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-call-completion-check:4] Set("PJSIP/186-0000003a", "CC_MODE=none") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-call-completion-check:5] GotoIf("PJSIP/186-0000003a", "1?end") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx_builtins.c: Goto (sub-call-completion-check,s,17)
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [s@sub-call-completion-check:17] Return("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [h@sub-local-dialing:6] NoOp("PJSIP/186-0000003a", "Call ended") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Executing [h@sub-local-dialing:7] Hangup("PJSIP/186-0000003a", "") in new stack
    [2020-11-22 16:01:23] VERBOSE[7150][C-00000031] pbx.c: Spawn extension (sub-local-dialing, h, 7) exited non-zero on 'PJSIP/186-0000003a'
    [2020-11-22 16:01:26] NOTICE[117917] res_pjsip/pjsip_distributor.c: Request 'OPTIONS' from '<sip:10d7d99b-a907-407d-ac46-5255ff5c876b@192.168.3.10>' failed for '192.168.3.10:5060' (callid: be29e2eb-2bd7-4782-b1f5-6685ef54ace9) - No matching endpoint found
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] bridge_channel.c: Channel PJSIP/199-00000038 left 'simple_bridge' basic-bridge <df684ed0-db0a-4dc3-8921-7205e21fd4d3>
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Spawn extension (trk-1-dial, 79250363499, 16) exited non-zero on 'PJSIP/199-00000038'
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [h@trk-1-dial:1] Gosub("PJSIP/199-00000038", "dynamic-routing-out,s,1(199,79250363499,ANSWER,1)") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [s@dynamic-routing-out:1] NoOp("PJSIP/199-00000038", "Test if save on dynamic routing list") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [s@dynamic-routing-out:2] Set("PJSIP/199-00000038", "CALLER=199") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [s@dynamic-routing-out:3] Set("PJSIP/199-00000038", "CALLED=79250363499") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [s@dynamic-routing-out:4] Set("PJSIP/199-00000038", "STATUS=ANSWER") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [s@dynamic-routing-out:5] Set("PJSIP/199-00000038", "TRKID=1") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [s@dynamic-routing-out:6] Set("PJSIP/199-00000038", "ALLOW_DR=yes") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [s@dynamic-routing-out:7] Set("PJSIP/199-00000038", "DYNROUTING_OMC=yes") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [s@dynamic-routing-out:8] GotoIf("PJSIP/199-00000038", "1?:comeback") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [s@dynamic-routing-out:9] System("PJSIP/199-00000038", "/usr/share/vitalpbx/scripts/dynamic_routing "out" "199" "79250363499" "ANSWER" "1" "yes" "2d97ae06e1471d24"") in new stack
    [2020-11-22 16:01:29] VERBOSE[7136][C-00000030] bridge_channel.c: Channel PJSIP/956740-00000039 left 'simple_bridge' basic-bridge <df684ed0-db0a-4dc3-8921-7205e21fd4d3>
    [2020-11-22 16:01:29] VERBOSE[7135][C-00000030] app_mixmonitor.c: MixMonitor close filestream (mixed)
    [2020-11-22 16:01:29] VERBOSE[7135][C-00000030] app_mixmonitor.c: End MixMonitor Recording PJSIP/956740-00000039
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [s@dynamic-routing-out:10] Return("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Executing [h@trk-1-dial:2] Hangup("PJSIP/199-00000038", "") in new stack
    [2020-11-22 16:01:29] VERBOSE[7116][C-00000030] pbx.c: Spawn extension (trk-1-dial, h, 2) exited non-zero on 'PJSIP/199-00000038'
    [2020-11-22 16:01:29] VERBOSE[1322] chan_sip.c: Extension Changed 199[extension-hints] new state Idle for Notify User 200
    And screen with “failed” in CDR
    You must be logged in to view attached files.
    0
Viewing 1 replies (of 1 total)
  • The forum ‘Reporting an Issue’ is closed to new topics and replies.
